Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
trunk opens when brake is applid
Old 04-20-2024, 04:54 PM
steve kelly's Avatar
Default trunk opens when brake is applid
I have a 2008 eclipse spyder and when the brakes are applied the trunk switch releases the trunk,anyone ever have this problem.I replaced the trunk with one from a salvage for hail damage.Its like when the brakes are applied it sends direct power to the trunk
Old 04-21-2024, 11:51 AM
Widgmaster's Avatar
Are you using the locking system that came with your car or did you install the new trunk lid and use the lock that was on it?
Old 04-22-2024, 07:38 PM
I had the one that came on the trunk lid when i replaced it (hail damage) but I changed it to the original one that was on the old hood but it did the same thing.I seems to have power sent to it when the brake is applied.Evrytime you push the brake pedal and release it you can hear the trunk release activate.
Old 04-26-2024, 09:20 PM
So I FIGURED OUT WHAT MY PROBLEM WAS,WHEN IT HAD THE HAIL DAMAGE IT BUSTED THE REAR SPOILER i ORDERED ONE ON LINE FROM A SALVAGE AND WHEN I UNPLUGED IT THE PROBLEM WENT AWAY iT MUST HAVE HAD A SHORT IN IT.ANYWAY PROBLEM SOLVED
Homer1959
11-24-2020 05:10 PM
RMede89202
4th Generation
12-05-2012 01:27 PM
pravindrareddy
03-22-2012 01:50 PM
martin_mac
4th Generation
02-04-2012 09:31 AM
Gstfat
03-27-2007 10:56 AM
Quick Reply: trunk opens when brake is applid
