error code P0506
Old 07-15-2010, 06:09 PM
dalendianejanzen's Avatar
Default error code P0506
On my 05 Endeavor my service engine light came on and the meter says, P0506, low idle RPM. I have no low RPM issues or rough running at all. Any suggestions what is causing the light to come on?
Old 08-01-2010, 02:52 AM
bbazookajoe's Avatar
This information is from mitsubi****echinfo website.
This code is tripped when there is a difference greater than 100rpm's between the engine speed and the "target" engine speed.
"TROUBLESHOOTING HINTS (The most likely causes for this code to be set are
*Throttle valve area is dirty.
* PCM failed."
It says clean the throttle valve area completely, erase the code and see if it resets. It says the next step is to replace the PCM. Personally i'd try replacing the throttle position sensor and motor before I did that.
This is assuming you've already replaced the air filter and checked the housing.
Old 07-21-2013, 12:26 AM
catacami's Avatar
Exclamation How To Clean Throttle Body 2003, 2004, 2005 & 2006 Mitsubishi Outlander Engine Light
Watch my YouTube clip
fastbg25
02-21-2008 11:42 PM
anitarose122
06-28-2007 11:08 PM
sp1viper
04-24-2007 04:36 PM
Nubiebubie_GSX
06-07-2006 02:16 PM
Quick Reply: error code P0506
