2001 mitsubishi montero codes
Old 10-02-2009, 12:22 PM
ziggy66's Avatar
Default 2001 mitsubishi montero codes
hi last month the check engine light went on i found out i had a p0155 code the 02 sensor so i left it. then i had a fire in the engine not bad just the cap was left off after the oil change and i drove for a while until i saw smoke oil was spraying on the exhaust shield. there was a small fire on the shield so someone sprayed a fire extinguisher in there but it got all in the valve cover. so i had it towed to a garage the cleaned everything out and changed the oil.
now after a week or so i go to emission and fail i got two new codes now p0173 and p0170 is that from the fire and what are they
Old 10-02-2009, 01:49 PM
challenger4x4's Avatar
P0170 Fuel Trim Malfunction (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
There are a lot of problems that can cause these codes to show up but the most common is a vacuum leak. Maybe something melted?
Old 09-27-2010, 08:15 PM
osanyin's Avatar
Hello,
I'm curious to find out if you were able to clear the codes. What was causing the codes to come up?
Davie-h
11-11-2013 01:25 PM
membreya
04-18-2013 12:50 AM
admonte
03-29-2013 08:43 AM
coolme
06-30-2006 04:37 PM
coolme
1st Generation
06-30-2006 02:51 PM
Quick Reply: 2001 mitsubishi montero codes
