2001 montero xls rotors
Old 09-30-2010, 06:15 AM
osanyin's Avatar
Default 2001 montero xls rotors
I just replaced the front rotors on my 2001 and I noticed that the factory ones had screws attaching them to the hub. The after markets I bought don't have the hole for the screws. Could anyone tell me what the purpose of those screws is? Should I drill the rotors to put the screws in?
Old 09-30-2010, 12:55 PM
redturboeclipse's Avatar
photos?
Old 09-30-2010, 08:56 PM
mtc137's Avatar
The screws don't attach the rotor to the hub, they're there as a means to break the rotor loose from the hub in the event they are stuck to the hub by corrosion or if just difficult to remove by hand. You thread a bolt through each hole (not sure what # bolt at the moment) and tighten each until the rotor separates from the hub. I wouldn't be concerned if you don't have holes on the new ones, a basic hammer always did the trick for me anyway
Old 10-01-2010, 11:26 AM
osanyin's Avatar
Thumbs up
thanks for your help!
paparoach
12-22-2013 06:14 PM
redturboeclipse
03-01-2011 10:38 PM
mnewland00
12-23-2010 05:31 PM
D.P.
02-19-2010 11:12 PM
ttplusd
02-02-2009 06:26 PM
Quick Reply: 2001 montero xls rotors
