2002 montero xls service engine soon light
Old 12-15-2011, 10:58 PM
lizb's Avatar
Default 2002 montero xls service engine soon light
I just recently bought a 2002 montero xls. I had my mechanic check it out, did car facts etc. No problems found. Immediately I started having problems with it. First the service engine soon light came on, needed new catalytic converter, then there was some sort of battery connection issue where the car just died. After those 2 repairs, the car started idling really low at slow speeds and died at complete stops. On top of all that, it runs on or just below 3k rpm when going 60mph. Has anyone else had similar issues? Any advice? Thanks!
Old 12-16-2011, 09:12 AM
challenger4x4's Avatar
Not sure about the 3K @ 60MPH. Sounds normal.
As far as the idle though, the idle adaptive memory was probably erased when the battery work was done and the idle air control (IAC) motor is now starting at a nearly closed position. If there is carbon and/or oil build-up around the throttle plate, the amount of air that can flow past it is limited, which causes the poor or erratic idle.
YOU JUST NEED TO CLEAN THE THROTTLE BODY AND THROTTLE PLATE.
Read the first FAQ on this page:
Montero Sport Online Forum - F A Q- Updated 3/12/05
Old 12-17-2011, 10:42 AM
lizb's Avatar
Smile
Thank you so much, this is more than helpful!
ejohnson_18
05-19-2011 07:48 AM
Mike21
06-30-2010 10:14 AM
gigi
08-20-2008 07:53 PM
4GD
4th Generation
05-02-2008 08:02 PM
antlip
03-02-2008 01:10 PM
Quick Reply: 2002 montero xls service engine soon light
