PG Assembly Malfunction on Montero
Old 09-14-2007, 07:11 PM
foolane's Avatar
Default PG Assembly Malfunction on Montero
Get DTC Code P1715 - PG Assembly malfunction! What does this mean? Is my transmission cooked or is it just an Electronics issue?Should I just reset it? Please advise. Thanks a lot! The Freeze frame info is below. If I clear it, what happens next?
OBD2 Diagnostic Report
Freeze Frame
Parameter Description Value
DTC for which Freeze Frame was Stored P1715
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 25.10 %
Engine Coolant Temp 195.80 °F
Short Term Fuel Trim - Bank 1 7.03 %
Long Term Fuel Trim - Bank 1 4.69 %
Short Term Fuel Trim - Bank 2 5.47 %
Long Term Fuel Trim - Bank 2 5.47 %
Engine RPM 675 rpm
Vehicle Speed Sensor 2.49 mph
Report# 1 /Date: 9-12-2007
Old 09-15-2007, 10:02 AM
Default RE: PG Assembly Malfunction on Montero
you CANNOT use the PCM code to properly diagnose trans issues. The code is a generic code, not applying to the actual problem.
you need to access the trans computer to properly begin diagnosing.
Old 09-17-2007, 01:23 PM
Also year and model of Montero would be nice to know.
Old 09-22-2007, 06:59 PM
foolane's Avatar
1997 Montero LS
Old 05-14-2013, 05:59 PM
Richigo07's Avatar
I got the long term fuel trim bank2 stuck the line goes –------------------ dont do nothing what can i do?montero limited 2001
Old 05-14-2013, 06:16 PM
Your post makes no sense. Start by making a thread, and typing in coherent sentences.
newyorkmitsu
05-10-2017 11:20 AM
tdennehy
10-23-2014 12:35 AM
Sparkmdb
05-02-2011 06:46 PM
ann
07-19-2010 09:50 PM
bkcoburn
02-15-2008 09:23 AM
Quick Reply: PG Assembly Malfunction on Montero
