98 mitsubishi eclipse 2.0. error codes p0171/p0301
My daughter has a 98 mitsubishi eclipse 2.0.129,000miles she has replaced the plugs and wires, It has error codes p0171 and p0301 lean fuel, i have checked for vacuum and gasket leaks with brake cleaner no indication of leak any where have checked fuel injectors for continuity all around 14 ohms. I have erased codes but eventually come back, at first start will run and rev perfect for 3-5 minutes then run a little rough, if i turn it off and restart will run perfect, this happens on all restarts and after 3-5 min it returns to run rough. has new air cleaner, new o2 senors, new plugs and wires and have run lucas injector cleaner instead of taking rail and injectors out and cleaned manifold sensor. any help would be appreciated thanks for reading hoyze1@yahoo.com
My daughter has a 98 mitsubishi eclipse if i turn it off and restart will run perfect, this happens on all restarts and after 3-5 min it returns to run rough any help would be appreciated thanks for reading hoyze1@yahoo.com
You might want to take a look at Scannerdanner channel over on utube, he explains how these systems work! Look thourgh all his videos for o2 sensor testing! You wont be disappointed!
Good luck with daughters car!
Denny St. Louis
psychoscoot
09-24-2009 07:59 PM
